Garage floor paint
    Garage floor paint
    I'm going to paint my garage floor soon, want to prevent dust and also tidy the place up. I can also then mop up the spills etc more easily
    I've had some advice to seal the concrete with watered down PVA to seal it first - then 2-3 coats of paint...any got any advice?
  • rj scotty
    • May 2006
    • 2195
    The PVA trick is a very good idea
    Spend the extra few quid and get a 2pak paint lasts much, much longer.
    Have been meaning to do this for the last 4 years
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
    • varia
      • 821
      • Current: United States
      I dont know about anything the materials in UK, but here in the usa you can buy a garage fllor epoxy kit.
      I did it many times and a friend of mine doing this for living.
      If you want to this or similar, just pm and i can tell you few tricks.
      Chris
      • benntenn67
        • Jun 2009
        • 859
        Hi, I can recommend this - choice of colours & durable
        We’ve been pioneering a world of possibilities to bring surfaces to life for well over 200 years. As experts in making coatings, there’s a good chance you’re only ever a few meters away from one of our products. Our world class portfolio of brands – including Dulux, International, Sikkens and Interpon – is trusted by customers around the globe. We’re active in more than 150 countries and have set our sights on becoming the global industry leader. It’s what you’d expect from the most sustainable paints company, which has been inventing the future for more than two centuries.
        Audi S2 Coupe 1995
        VW Passat GL5 (hatch) 1986
        VW Passat GL 1.8 (saloon) 1986
        Carrera Subway 8
          cheers guys, epoxy seems the way to go it needs to last for as long as possible
          • 20Vcqdriver
            • 829
            http://www.international-paints.co.u...loor_paint.jsp
            Yep this is what I used just washed the floor first, let it dry and painted it on nice and thick..ish. Been down for 5 years now without an issue. Just need to wash it now as after the garage clearout it is s*** up..
            1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
            2004 A4 2.5TDi convertible, re-mapped to 180bhp
            2011 A5 sportback 3TDi-Backbox delete, remap
            • epic
              • 1317
              I'd recommend these guys
              link
              • bluequattro
                • 2960
                PVA is great start, I did that for a house when i put 12 tons of new concrete floor in!
                How about tiling it? Lasts much longer, I ve been thinking of doing that in my garage.
                • andy10v
                  • 5996
                  How robust is that?
                  Sold ABY-stock
                    the right grade tiles aren't cheap, plus you need to use a levelling compound first, PITA
                    • nip
                      • Apr 2006
                      • 1786
                      • Home: United Kingdom Current: Abu Dhabi
                      how about a rubber stud tile
                      • JP
                        • 1858
                        My mate fitted the rubber tiles to his garage and put the sealing coating on they recommended and he can't wait for the sealant to stop flaking of. It's warm in there I give it that but thats about it.
                        I've tried various paints in my workshop over the years with a yearly recoat. But it takes a lot of abuse and looks pants quickly, this time round I'm sanding it down to get rid of high spots and coating it with this HD industrial stuff which they said can go over the existing surface finish. http://www.rustoleum-mathys.co.uk/pr...Pegakote_id400 They did recommend a higher build one that they use in the catering industry that finishes as if if one large ceramic tile but I couldn't warrant £300 for such a small space without knowing it was going to work for my application.
                        Will let you know how the pegakote goes. Will take a before pic as it is, then sanded down, then coated, then in two weeks when back from the US when it is fully cured (although 2 pack they recommend 7 days before heavy use).
                        UrS6 Stroker + HTA3586 =
