Right then, I've removed the AC from my S2, including replacing the original heater box and evapourator for a standard system from a non AC audi 80. (I had to do it properly or not at all)
This obviously leaves me with a large hole in the bulkhead where the pipes went through.
So did audi make a grommet or blanking plate for cars which wern't fitted with AC or was the hole just never made? If anyone has had the same problem, what did you do?
Welding doesn't look like an option as the wiring loom is too close on the inside, and the paint and seam sealer on the engine bay side would burn off.
I'm not looking for a debate whether AC is good or bad, I have my own reasons for removing it and thats that
1. its heavy
2. its makes life difficult when working doing jobs in the engine bay,
3. the condenser blocks airflow to the main rad
4. future replacement of the main rad for a larger aluminium item will be easier
5. it always breaks and spare parts are expensive
1. its heavy
