Leaky water pipes
  • Christophski
    • 3632
    Leaky water pipes
    Hey guys
    Anyonoe got or know the part numbers for the turbo cooing pipes that runn down the block? They are on the drivers side of the engine bay and run down the side of the block and look like they go to the turbo. They are metal, or braided. Mine are leaking from the bottom joints so I want to get this sorted before to long.
    If you have them and know they dont leak or if you know the part numbers can you let me know please?
    Thanks
    Chris
  • Christophski
    • 3632
    Sorry should have said its an 93 ABY
    • Rusty
      • 18953
      Give s2avant a shout - he'll be able to get you the prices on OEM VAG ones
      • s2avant
        • 2426
        Reference your PM, are you referring to items 23 and 25 on this picture?
        If so the part numbers are as follows:
        Item 23: 034121497B
        £119.73 + VAT retail
        Item 25: 034121492D
        £52.94 + VAT retail
        They are both on back order so would take 7-10 days to get from Germany.
        Ben
        • Jonnybravo
          • Aug 2008
          • 2051
          £119 !
          That is one expensive bit of pipe.
          • Christophski
            • 3632
            Ok, anyone got a set of these kicking around as I need new ones I think but havent got the money for brand new ones at the mo as they look a bit expensive!
            Thanks
            • Jonnybravo
              • Aug 2008
              • 2051
              I have dug out the item 25 for you Chris, I think you may find that Mike ( Europeanme) has the other one as it was probably still attached to the bottom end I sold him a while back.
              Item 25 has the vaccum pipe attached to it. I'll throw it in FOC with the other bits you paid for
              • Christophski
                • 3632
                Cheers bud. Your a LEGEND! Will get in toch with Europeanme and ask him if he still has it.
                Thanks
