I'd also go with flywheel pin but has the fuel pump relay been ruled out ?
It's in position #10 in the main fusebox... You can pop it out and gently tease it's lid off to expose the contacts... Gently refit it and see if the contacts close on cranking. If it doesnt then you can use insul tape to close it manually for a test.
Also - with the ignition on... Check you get 12V on side of the fuel injectors. That proves your ecu holding relay and wiring is good. Think you tried a spare ecu but is good to check.
How many miles/kilometres are on your car?
