Adjusting Coupe side windows
  • gripper
    • Jun 2008
    • 1156
    I have just replaced the complete drivers window mech on my B4 coupe. Before I replaced these I had no leaks whatsoever from this door.
    I replaced the shims/spacers behind the mounting bolts as they came on my old window frame. Since then I have moved these around but still cannot get a seal like it was before
    Any tips or the correct procedure to remedy this would be greatly appreciated.
    My door seal is in excellent condition and my door sealing pieces are brand new
    Cheers, Chris
    For what this cost me so far I could have bought an S2
  • gripper
    • Jun 2008
    • 1156
    Anyone ?
    For something which is so commonly replaced on coupes I cannot believe no-one has any words of advise
    I've fiddled with it and moved spacers from one location to another but its still not right
    • Audi_CQ
      • 940
      • Country: Norway
      Thicker or multiple shims is the way to go.
      • recurveandy
        • Oct 2006
        • 515
        Takes a few hours and lots of patience I'm afraid
        Gently pour water around the window to check for leaks and when your happy with it, take it for a spin to check for wind noise before putting the door back together.
        Did I give you a box of shims when you picked the frame up?
        If not I'll pop them in the post for you if you need more
        1989 NG Q Pick-up (Daily)
        2002 ASZ Golf (Doris' Daily)
        1997 AJK-G2 A6 Avant Q (In surgery)
        1999 AGZ Bora (Daily 2)
        1994 ABC A6 Avant (Spare)
        1984 JS Coupe GT (Slow progress)
        1982 WN Coupe GT5 (Spare)
        1983 MK1 Golf GTI Pirelli (In storage)
          yup, trial and error unfortunately... the window mech is adjustable in 4 ways - the thickness of the spacer shims, the up-down and front-back movement of the bolts and also the window glass itself is adjustble on the cables.. plus the cables are adjustable in terms of tension, and also the door can be adjuasted in two directions too have fun!
          • andy10v
            • 5996
            Swear or hit something, it won't help but it might make you feel better.
            Plus the little triangle at the front can be adjusted as well
            Sold ABY-stock
            • gripper
              • Jun 2008
              • 1156
              Thanks for the replies guys
              Looks like I'm in for some fun and games then
              I'm thinking of taking my coupe up to Allaudi (just up the road from me) and let one of there guru's loose on it, but not if they will charge me a days labour !
              • gripper
                • Jun 2008
                • 1156
                @ Andy, might need those extra spacers bud but will let you know
                • SteveCat
                  • 29
                  I've got some you can have too if you need extra!
                  Least I can do for letting you down on the wood,which I want but canne afford due to stuff my Coupes told me I need first,by breaking.And breeeeeeath
                  Steve
                  • Tom_
                    • Oct 2007
                    • 1301
                    • Country: Czech Republic
                    i want to ajdustable the front side windows,i dont know ho. Can someone mark on the pictures,which bolts i must remove or allow?
                    Uploaded with ImageShack.us
                    Audi Coupe Quattro 2.3 20V
