Gearbox
  • Si Blythe
    • Jul 2005
    • 346
    Gearbox
    Anyone fancy helping me to remove the gearbox on my ABY Avant. I am in Shrewsbury and have a covered hangar and access to a ramp. I am in Shawbury near Shrewsbury.
    Si
    You might leave the S2 fold every so often - but you'll always come back!
  • simon20vq
    • Dec 2010
    • 1379
    If I was closer to you it would have been a pleasure, thank goodness I don't live near you
    Hope you don't mind me raising a question, Just removed same from car the other day BUT I left the engine in situ is it better to remove the whole front subframe with engine in situ??
    • re2500
      • May 2007
      • 2185
      Ive removed the gearbox from my ABY recently to replace the clutch. I found it such a pain to get the gearbox mated back to the engine whilst the car was just on axle stands that ive given up and decided to remove the engine and put the engine and gearbox back in as one (how i did it last time) theres no such thing as a shortcut, lol! I think it would be much easier with a ramp/lift though...
      Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
      "Difficult is worth doing"
      • simon20vq
        • Dec 2010
        • 1379
        I sort of thought it would be a pain to get back in because of fouling the steering track rods but I've not done it enough to see the best way yet. Wonder if it would less time and effort in the long run to remove it all. Anyone else?
        • Jonnybravo
          • Aug 2008
          • 2051
          Sod removing the engine, the 6 speed goes back in but it is awkward.
          From memory although it was a while back now
          Farb and subframe off
          Downpipe and exhaust off
          Shafts out and prop
          Possibly steering arms and tie them up
          Unplug wiring connectors off gearbox
          Remove slave cylinder flexi pipe
          We used a big jack with a piece of strong wood to lift it back in then one if us on each side to lift it off the jack and onto the engine.
          Don't forget some copper slip on the input shaft and you may need to put a jack under the front of the engine to stop it tilting forward once the box is off, tilt the engine back slightly to help get the box back on but be careful of the crank pulley against the ic.
          We did it on axle stands, not easy but managed it in half a day I'd say
          You will want a big jack
          • re2500
            • May 2007
            • 2185
            I tried it almost exactly as above, but ended up lying under there for about 3 hours trying o get that fricking input shaft back in but she wasnt having it........so engine out!
            • simon20vq
              • Dec 2010
              • 1379
              Was/is the clutch plate aleigned properly that would stop the G/box going on? If steering rods were out the way I think it would be the best way.
              • Si Blythe
                • Jul 2005
                • 346
                I am thinking engine out too, the big bonus is that the car club has a ramp and I have a permanent slot in the hangar too - thankfully! I am thinking mini resto will probably a good few months off the road.
                If anyone can help I don't expect them to do it for free.
