old topic im sorry, diff lock speed limiter
  • R31LLY
    • Mar 2011
    • 154
    can someone please give me clear instructions how to stop the speed controller kicking in when the diff lock is pressed.
    my confusion comes from ive seen some pics of people cuttin a blue and white wire under the switch itself, which seems to make one of my wheels lock up and then when i read on i see people talking about the wiring under the rear seats
    anybody know which wires i need to locate and what to do with them
    many thanks reilly
  • sam80quattro
    • Oct 2006
    • 1496
    under the rear seats, cut the blue/white wire, enjoy
    • R31LLY
      • Mar 2011
      • 154
      and i take it it all works as normal via the button, it just stays on until its released with the button again??
      • Zoig
        • Sep 2008
        • 555
        Yes.
        • R31LLY
          • Mar 2011
          • 154
          nice one thanks guys :-)
          • spont
            • Apr 2011
            • 13
            hmmmm very interesting what about a urs6 with automatic diff lock what could be done there?
            • ian4455
              • Nov 2010
              • 787
              i asked the same question some time ago, here is the pic -
              • andy10v
                • 5996
                As in EDL?
                Sold ABY-stock
                • blackrat
                  • Mar 2010
                  • 49
                  Ok..so those who have done this,in simple terms what are the pros and cons??
                  • Zoig
                    • Sep 2008
                    • 555
                    Originally posted by andy10v
                    As in EDL?
                    You can just add in a normal diff lock from UrS4, I did that on my car.
                      As blackrat says, I'd be keen to know also.
                      Thanks.
                      • Fat Audi 80
                        • 10547
                        The locking diff is not designed to work over 25mph so cutting the blue and white wire and then activating the diff lock over 25 mph might break it!
                        The Perfectionist
                        • Dan
                          • Jun 2008
                          • 1242
                          Yeah, the con is that you have to remember to turn it off yourself!
                          Obviously you might want to leave it on on snow/ice, but it'll ****** it on tarmac.
                          1993 ABY Coupe | BMW R1200 GS
                          A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
                          • andy10v
                            • 5996
                            Pros;
                            You can have the diff locked at higher speeds, can be useful for climbing hills in snow at higher speeds.
                            It is easier to drive sideways if you so wish.
                            Cons
                            You have to disengage manually
                            If you have it on in the dry it will chew the tyres and have some interesting handling characteristics if trying to drive normally
                            Based on experience I doubt it will break if engaging/disengaging at higher speeds, however I would still advise locking and unlocking when stationary as it is much more sympathetic. The lock is a collar that is controlled by a fork which makes the collar slides over two sets of splines to lock both outputs.
                            If you want to lock and unlock at higher speeds lifting of the power (if accelerating, or use the throttle lightly if engine braking) momentarily will allow it lock instantly, otherwise it will take a while.
                            The lock itself it pretty beefy and one engaged is not going to brake.
                            Sold ABY-stock
                            • R31LLY
                              • Mar 2011
                              • 154
                              sweet. . . ive cut mine and it stays locked after 25mph now :-D now i need to find a open place to master kicking it out smoothly, i can control it when its out i just dont want to mess up kicking it out on the road and smash a kerb, thats not what s2's are for lol
