Interesting wheel adaptor solution......
  • bikerjim
    • Feb 2008
    • 1028
    I wonder if something similar could be done for 4x108 to 5x112 ???
    http://www.ebay.co.uk/itm/PCD-Wheels...#ht_3763wt_929
  • bambridge
    • May 2009
    • 609
    I have heard about these!!!!
    • Rusty
      • 18953
      So you only attach with 3 bolts? That's the stupidest idea I've head in a while...
        4 bolts, the 4th one bolts into the hub and dual threaded so a bolt can be bolted into it
        • Nik0las
          • 1345
          • Country: Bulgaria
          Easyer willl be to get hubs from A4 b5 quattro and swap them with yours. As far I know earlier models has same bearings
          • bikerjim
            • Feb 2008
            • 1028
            This is probably true, I just thought it was in interesting solution and worth sharing.
            The guy isn't selling any for 4x108 but I bet if its possible they might sell. Mind you For 2 pairs I suppose your looking at £240, so not really viable if you can get hold of s2 fronts and A4 rear disks. Just thinkin out loud lol
            • terrybullwon
              • Mar 2006
              • 8782
              I am getting 5x112 to 5x114.3 here
              Design Deluxe Mfg. (wheeladapter.com). Phone: (818) 992-5700. Fax: (818) 337-2471. Address: 21300 Deering Court, Canoga Park, CA 91304.
              Chef
              • bambridge
                • May 2009
                • 609
                Andy, you wind the eccentric boss into the hub, then attach the spacer.
                But somehow you need to get the eccentric boss in the right place to screw the wheel bolt into
                I would think the boss would need to be tight against the hub, but would the bolt hole be in the right place
                • Rusty
                  • 18953
                  I was viewing on eBay mobile and it forgot to show me all of the other pictures
                  It's an innovative solution but I'd not want to try it on something that was actually fast - more of a show car solution IMHO but then I'm an Engineer and I've had a wheel try and fall off on a couple of occasions... so I'm never going to be overly keen on more things that can go wrong.
                  • bikerjim
                    • Feb 2008
                    • 1028
                    Yeah I was wondering about this too?!
                    Yeah definitely, looking at the closeness of the other holes too, there isn't alot of meat there really. Could a bad jolt from a pothole cause it to crack?!
                    • Rusty
                      • 18953
                      Obviously the thinner areas around the holes will be under higher stress than the areas where the holes are better spaced and so material quality is rather important here - cheap chinese metal and you'll end up with some issues for sure.
