Impact guns do's dont's
  • rs2315
    • Jun 2006
    • 867
    Just about to purchase an impact gun, and was wanting some user info from seasoned pro's.
    Borrowed GT500's Snap On recently for small job, but I'd just like your views.
    Cheers.
    rs2315.
    Do use the correct impact gun sockets
    Do NOT use the gun to remove OR install the crank bolt during a timing belt change.
    • ian4455
      • Nov 2010
      • 787
      make sure you wear safety glasses, we use these all the time at work.
      • Tap Towers
        • Dec 2010
        • 220
        We have used loads of different ones at work, and the only ones that seem to last are the snap on ones.
        If your useage warrants spending decent money, Id go for that.
        An air powered gun and compressor are a slighly cheaper alternative, if not as portable.
        05 Allroad
        05 Seat Alhambra
        • TTQ-A4Q
          • Jun 2011
          • 5
          I use an 18v Snap on almost daily, double the price of the likes of sealy and clarke but worth the extra IMO. A friend of mine has a clarke does the job but Snap on Knocks spots of it for Torque and battery life.
          • Ducky
            • May 2006
            • 636
            Snap-On all the way, you DO get what you pay for in this case!
            • rs2315
              • Jun 2006
              • 867
              Can you give reasons?
              Cheers.
              rs2315.
              • rs2315
                • Jun 2006
                • 867
                Which models do you recommend for our cars?
                rs2315.
                • nip
                  • Apr 2006
                  • 1786
                  • Home: United Kingdom Current: Abu Dhabi
                  make sure its charged
                  • HMS-S6
                    • Jan 2010
                    • 1164
                    I agree, but if you can get an early version of the latest gun, the clip that holds the battery is NOT green, they are supposed the be identical but there not, the early ones have more power. We have 6 and this the case with all of them.
                    • Tony Stark
                      • Nov 2009
                      • 288
                      I have a mid range bluepoint air impact gun which is ok but seems to jump around alot in my hands when gunning off something tight like its unbalanced or something so thats power wasted.
                      I too have a new snap-on 18v 1/2 inch jobbie which is the best tool i bought for a while tis a bit heavy but theres no need to oil it daily, no grubby air line to tangle or potentially drag on bodywork, good charger, two batteries and it works very well.
                      If not snap-on then ingersoll rand, i really like their air tools and some goodun's pop up on egay every now and then.
                      Oil it regularly and bleed the compressor of water every week and the above last and work well.
                      Dave
                      Also with air tools they cant be overloaded and possibly burnt out like the battery powered versions.
                      • TDi90
                        • Nov 2009
                        • 272
                        INGERSOLL - RAND.
                        nothing else.
                        • baltiboyS2
                          • 965
                          Originally posted by TDi90
                          INGERSOLL - RAND.
                          nothing else.
                          All the way !!
                          cheers Raj
                          • benntenn67
                            • Jun 2009
                            • 859
                            egay
                            INGERSOLL - RAND.
                            nothing else.
                            Audi S2 Coupe 1995
                            VW Passat GL5 (hatch) 1986
                            VW Passat GL 1.8 (saloon) 1986
                            Carrera Subway 8
                            • andy10v
                              • 5996
                              Don't ever pull the trigger with a socket on it when not undoing/doing something up, it can fire the socket!
                              Good ones are a nice luxury
                              Sold ABY-stock
