Boost gauge - daft question!
  • bikerjim
    • Feb 2008
    • 1028
    This a bit embarrassing but i don't know so I'll ask.
    Where is a good place to plumb in a boost gauge?
    The vacuum line to the fuel pressure regulator?
    Cheers all
    Jim
  • Tony Stark
    • Nov 2009
    • 288
    I mounted mine in the centre heater vent. The pipe then runs down behind the the cd player and across to the passenger footwell area, and to a T-peice thats inline with the vacuum pipe going to the ecu, which is below the glove box.
    • Dingo
      • Jan 2008
      • 229
      I think the easiest is to tee in next to the ecu ( under the passenger glove box )
      • prj
        • Mar 2010
        • 6308
        Well the best would be of course a separate vacuum source.
        Because plumbing it at the FPR can be potentially dangerous.
        But yeah, most people (including me when mapping) put a T piece just before the ECU.
        • sam80quattro
          • Oct 2006
          • 1496
          1.8t so no feed to the ecu unfortunately, i'm not running a dumpvalve on mine so took my feed from the manifold where the dumpvalve plumbs in. however almost all 1.8t's i have seen do t into the fuel pressure regulator
          • bikerjim
            • Feb 2008
            • 1028
            Ahh yeah sorry it is a 1.8t. I can plumb into either the dv line or the fpr line. Is either better?
            • prj
              • Mar 2010
              • 6308
              DV line is safer.
              • bikerjim
                • Feb 2008
                • 1028
                Ok cool, thanks.
