What Fuel Lines?
  • bikerjim
    • Feb 2008
    • 1028
    What Fuel Lines?
    Hi guys,
    I want to tidy up my fuel lines on my 1.8t, you can see them running to some pipes I made up at the bulkhead -
    I would like to put some nice braided lines in but having priced up the pipe and fittings it works out very expensive.
    My question is, when is it necessary to use fancy hose with AN fittings?
    Can I use a push-on type hose with flared hard lines?
    The stock fuel pressure is 4 bar.
    I want to run lines from the fuel rail to either just under the car or just below the brake fluid reservoir.
    Let me know your thoughts
  • willg54
    • Jun 2009
    • 2055
    it's not cheap but its worth it and finishes the engine bay off nicely! Cost be about £80 from speedflow i think.
    • bikerjim
      • Feb 2008
      • 1028
      Agreed, they look the absolute nuts. But it would be almost £80 just for the hose, let alone the fittings. I would need about 4meters of hose I reckon to get them so the joints are hidden out the way, plus around 6-8 fittings.
      Im wondering if I can do something that looks reasonable that wont cost a fortune.
      • willg54
        • Jun 2009
        • 2055
        naaaaah -6 is only £17.58 per meter...2 max you'll need!
        Then 2 tube nuts for the hard lines, 2 straight -6, possibly 2 bosch fuel rail adaptors then what ever you need to fix to them. so 8 fittings...
        if you do it, dont by the cheapy ones, they break.
        check out http://www.speedflowshop.co.uk/-06-1...-06-1064-p.asp
        • willg54
          • Jun 2009
          • 2055
          i may even have some spare hose that will do you
          • bikerjim
            • Feb 2008
            • 1028
            Hmm this sounds tempting, let me know what you have.
            I reckon it would be more than 2 meters (1 per line) to get to the fluid res?! Maybe not much more mind.
            Correct, I would need:
            1 x M14 x 1.5 to 6AN adaptor
            3 x straight male 6AN fittings
            2 x hard-line to 6AN adaptors
            The return from the fuel rail is just a push on barb type fitting.
            £80 is still a fair old chunk, I was trying to think of something for around half that.
            • bikerjim
              • Feb 2008
              • 1028
              Just done a quick check on speedflow and including vat and shipping its gona be over £100
              • bikerjim
                • Feb 2008
                • 1028
                Anyone else got any solutions or ideas?
                • Rusty
                  • 18953
                  Look on Merlin Motorsport, they have loads of fuel stuff on there.
                  • sam80quattro
                    • Oct 2006
                    • 1496
                    5 cylinder fuel lines are in the middle of the bay. maybe get some of those...
                    excuse the mess, tidied up a bit since then
