Diff Mounts and Gear Box Mounts
  • Martin62
    • Jan 2011
    • 187
    Just started the refurb of my '96 Coupe rear sub frame and the diff mounts, not surprisingly, are shot !
    Can anyone confirm whether or not the 2 mountings for reacting the torque on the diff are the same as the gear box mounting ?
    I have 2 different part numbers suggesting they are not the same but I think I remember reading on here that they are.
    I notice GSF are selling the gear box mount for £9, does anyone have experience of the quality of GSF stuff.
    Cheers,
    Martin
  • re2500
    • May 2007
    • 2185
    On an ABY the diff mounts and gearbox mounts are a slightly different height,the ABY gb mounts are slightly shorter. on a 3B they are the same.
    BUT, i have an ABY and i have used the same taller mounts front and rear (034 track density) and it seems to be fine to me. In fact everything seems to line up a little better if anything?
    Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
    "Difficult is worth doing"
    • Martin62
      • Jan 2011
      • 187
      Thanks for your reply.
      So, do you think the shorter mounts would be OK for the diff or would you anticipate problems with that arrangement ?
      • re2500
        • May 2007
        • 2185
        If you anticipate using the shorter (ABY GBox) mounts all round then you could simply fit a 5mm spacer (like a big washer) on the top of the mounts for the diff?
        • Martin62
          • Jan 2011
          • 187
          Ah, OK see what you mean.
          In that case, think I might go the OEM route.
          Thanks for your help, much appreciated.
          Martin
          • sam80quattro
            • Oct 2006
            • 1496
            i got a pair of gearbox mounts from eurocarparts last week for my 80 and they came to £4.70 each plus the vat after discount. was expecting them to be naff but there really quite stiff. wonder how long they will last
