right as some of you may remember ive not had the best luck with timing belts:
1) first time out after transplant, the belt tensioner failed = head off and 10 inlet valves
2) second time, 2 weeks after rebuild crank pulley failed = .......see above lol + all pulleys replaced, crank cam etc (my bad, didnt read up about belt failures!)
when it went back on the road this time the belt has allways ran off centre, i.e a bit of the belt hangs over the cam pulley, only bit that was different was the waterpump didnt have the disk on the front as all the ones listed were a different size/more teeth on the pump
anyone seen this before?
im pulling the motor out soon to change the clutch and flywheel, turbo and manifold and stick my 1000cc/min in there and i will change the belt and pump again but i want this matter resolved
any ideas or past problems with your or customers cars?
regards Sean
regards Sean
