I will admit I know absolutely b****r all about this but another forum member has very kindly offered to plug in and see if there are any error codes
Can this be used on my V6 CQ ?
The member has HEX-Key whatever that is and not Can, will this still work ?
Chris
For what this cost me so far I could have bought an S2
If you have a fuse box with the connectors shown on the left side of the diagram below and your friend has the proper adapter plugs to connect to them, then yes, he will be able to check for codes, etc. You might have similar plugs located somewhere under the dash if they are not in the fuse box.
