Poorly 2.6 coupe
  • Tobs 1
    • Dec 2009
    • 133
    Poorly 2.6 coupe
    Hi all.
    My 2.6 ABC is very poorly. I fitted 1 lambda sensor a few weeks ago to replace the right hand one to see if it would cure the engines lumpiness at low revs. It helped for a bit but now the car is even worse. It cuts out when at low revs, is sluggish, and sounds a bit iffy when being turned over (sounds like my old pug 309-bad!).
    I really want to get rid of the old girl (too expensive to run) so need to either fix or strip it :-(
    The rest of the car isn't too bad (except from needing new TRE's and top mounts)
    So whats the plan for her now? Break or fix?
    • Tobs 1
      • Dec 2009
      • 133
      I'm going to change the other lambda sensor then change the top mounts and TRE's. If it's still a bit dodgy i'll sell to someone with more time and spare money.
