Help!!
  • Tobs 1
    • Dec 2009
    • 133
    Help!!
    My 2.6 v6 cuts out whenever i put in the clutch at low revs (i.e doing a U-turn on a hill). This nearly caused me to drive into a level crossing gate as the steering lock came on at the same time. Is this a lack of fuelling problem or something to do with the ignition?
    sounds like a vacuum leak to me. by steering lock i guess you mean you lost steering assistance?
    • sidrick
      • Jan 2011
      • 1342
      The steering lock?! This shouldnt come on with the key at ignition II. Perhaps you're just not used to losing power steering?
      As said, if this is the case it souds like an air leak.
      • Tobs 1
        • Dec 2009
        • 133
        The engine completely shut off and the steering lock really did come on. I even heard it click as I was steering at the same time.
          I'd look at the ignition switch then. Very odd
