Oil cooler mounting for MOT
  • willg54
    • Jun 2009
    • 2055
    Quick question... I've put an oil cooler in place of the aux rad but its yet to be securely located and bolted down. It's currently held in by zipties and the braided lines.
    Would this be an mot failure?
    Sent from my HTC Desire using Tapatalk 2
  • cooperquattro
    • Jan 2011
    • 815
    no should be ok if its secure,mine is in there with 1 zip ty and 3 brackets....problem with putting it there is,on cold start up the oil pressure takes its time as it has to refill the cooler
      On cold start no oil would be going to the cooler, only when it gets to temp will the thermostat open and direct oil to the cooler
      • willg54
        • Jun 2009
        • 2055
        Thanks
        It's themostat controlled so shouldn't be open at cold start. Mines not had oil pressure issues
        • terrybullwon
          • Mar 2006
          • 8782
          As Jamo said.
          You shouldn't have a oil cooler plumbed in with out a thermostat other wise your motor will never get warm
          Chef
          • cooperquattro
            • Jan 2011
            • 815
            A stat in the oil cooler line???or is this built into the oil filter housing??
            • terrybullwon
              • Mar 2006
              • 8782
              the filter housing is the thermostat
              Chef
              • cooperquattro
                • Jan 2011
                • 815
                Phew,thought I was missing something then!
