So not an Audi but this is the best forum around from my experience so here goes...
So as most of you will probably know my van has been in limp mode for quite a few months. (10 months) Have done pretty much everything to it with a lack of any real codes being thrown for my van (VW T4 99 reg 102bhp 2.5tdi)
So last week VAGcom showed my pump timing was out so a mechanic mate set it up this weekend just been with DTI guages so it was spot on. Seems the locking collar on the adjuster screw (?) was not in and it was loose so pump timing was all over the place. Anyway it has run spot on for nearly 100 miles now but then on the way home from work last night it started running how it did before, basically not boosting. I checked the locking plate was in and the adjuster screw on the pump was tight and it all still is.
So my question is the following: If the internals of the pump are ruined will it do the above even with this screw done up tightly? Will the internals of a ruined pump make it run badly even if the timing hasnt slipped etc? I know I need to plug it in to VAGcom again to check the timing on the pump but my suspicion is the pump needs a rebuild and then setting up with the DTI guages again.
Basically will a pump run ok for a bit then throw itself out again if it is worn? Even without the timing belts slipping?
Any advice from the mechanics?
Thanks
Chris
Thanks
Chris
