Alternativ stroker
  • caterpillar
    • 2480
    Alternativ stroker
    Cheap alternativ stroker (5 POT!)
    some use the 2,5tdi verson in eurovan(AAT)... longer block 236, 81,00 bore, and the 2,5tdi cranc(95,5)
    then the second best
    the 2,4 diesel verson in eurovan(AAB). longer block 236mm, 79,5 bore, and the 2,4 d cranc (its 95,5mm too; but not the same cranc; different P/N)
    the 3. verson
    the 2,5liter in eurovan; but petrol 2,5liter (AAF) 110hp 10v injecktion)
    it does have the longer block 236, have the 81,00 bore (low comp piston; with deap pocket in; and the 95,5mm stroke( same cranc as the 2,4)...
    today i have dismantling the AAF verson from a eurovan; and take a lot of pics...
    and the i tryed a another head from a audi 90 10v on.. yea it will fit, but the last return hole in the block need to be blocked of...
    and you will get the 30mm wide camgear on...
    even the EM from the audi90 10v will fit too( same gasgeds too
    ATTACH]37002[/ATTACH] CIMG0494.jpg CIMG0495.jpg
  • Sleeper_Avant
    • 2372
    [img] image link [/img]
    1993 URS4 Avant Emerald Green 350+bhp
    1991 Ford Sierra Sapphire 4x4 in Magenta
    BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
    • caterpillar
      • 2480
      The last two.....
      • caterpillar
        • 2480
        more info about the AAF verson( 2,5liter petrol 10v....) the engine ive got( 360k on the clock) have the deeeep pocket in the pistons (10mm at least) and 24mm xpin.. and 150mm conrods (same as the 2,4 dieselconrods) ,but 95,5 stroke... the bottom end(block) is like 2,5liter TDI without the oilsquirter..
        so i thought i could use the piston from a petrol(3b or likely) 5pot, but the comnrods was bend in this org 2,5l petrol 10v... they are like the banana... and the does have 24mm xpin
