Rebuilding an RS2 turbo, help needed.
  • fish
    • Aug 2007
    • 2333
    • Home: United Kingdom Current: Sweden
    I have got an RS2 turbo that puffs some blue smoke on idle and i guess it wouldn´t suffer from a rebuild. would this kit work? http://www.turborebuild.co.uk/p/prod...+RACE+Bearing/ What´s the going rate for a rebuild in the UK?
    Audi 80 Competition -94 Daily driver
    www.garaget.org/fish for more pic´s of my cars
  • fish
    • Aug 2007
    • 2333
    Nobody?
    • 220bhp
      • 2578
      I don't think you can use that kit for a kkk7200 I had mine reconditioned at CR turbos and
      they had to source a new central core in order to do it.
      Its exspensive around £650, but there service was first class,door to door and quick.
      • filip.krticka
        • Sep 2008
        • 170
        • Home: Czech Republic
        Fish,
        Following ebay article was used for my RS2 turbo refurbishment. I’ve done this part by myself. Then I sent turbo for balancing which is very important thing to do. Result is not known yet, because I’m working on cylinder head refurbishment.
        http://www.ebay.de/itm/KKK-K24-rebui...#ht_2822wt_989
        • fish
          • Aug 2007
          • 2333
          Thanks mate! Did everything look the same as the original stuff and fit as it should? I am doing this part myself also.
          • fish
            • Aug 2007
            • 2333
            Is the core different in a 7200 than a 7000?
            • mcandmar
              • Apr 2004
              • 5118
              Yes has a larger shaft from memory. I "think" it shares more parts with a K26 than a K24.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • fish
                • Aug 2007
                • 2333
                Ok. i´ll buy that k7200 kit and give it a try then. Thanks!
                • filip.krticka
                  • Sep 2008
                  • 170
                  Fish,
                  I there are some differences. I have to find list of all parts used in K24-7200.
                  Best and cheapest option is to write an email to internet shop.
                  • fish
                    • Aug 2007
                    • 2333
                    Originally posted by filip.krticka
                    Fish,
                    But the kit you put in your link is correct? Will that kit fit my turbo? Did the kit you got fit in your turbo without modifications?
                    • david
                      • Oct 2008
                      • 1268
                      i have an rs2 rebuild kit with 360 degree that will fit without any problem.pm me if you want it.
                      i think that kit in the link should fit.
                      [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
                      RS2 VOLCANO BLACK] soon to be broken to bits
                      • fish
                        • Aug 2007
                        • 2333
                        PM:d
                        • filip.krticka
                          • Sep 2008
                          • 170
                          Link, that I sent you yesterday is correct for KKK24-7200 turbo.
                          S2 (KKK24-7000) and RS2 (KKK24-7200) are not the same, at least shaft is different. That was the main massage I would like to mention.
