im sure ive read before that there is a few on here that deal with land rover/range rovers...
a mate is having problems with his 51 plate RR and i said i would ask on here.
first started when he had rear brakes changed, drivers side is sticking on, the garage then replaced brake flexi. still same problem, am i right in thinking they have shoes within the disc for the handbrake?
then it overheated whilst driving on a dual carriageway, got home and left it for a week.
started the car and all seemed fine, although he did loose water, topped it up and seems fine apart from pulling away, it chugs, as if its misfiring, but it runs fine and if you floor it, its also fine, just part throttle or even no throttle aslong as you lift off the brakes it does the chugging/juddering. hard to describe it, like abs pulsing but on the throttle.
the pipe onto the inlet didnt look seated right so i undid the jubilee clip and moved it and there was air coming out over and sounded like exhaust, is this egr? and is that normal?
finally took the oil filler cap off and there was steam coming out, fired it up and there was quite a bit of steam constantly coming out, its definately steam, theres no oil smell and it evaporates on the rocker cover...
