7 or 13 pin towbar electrics?
  • 80Quattro
    • Sep 2006
    • 420
    • Home: United Kingdom Current: New Zealand
    I've finally got hold of a Westfalia towbar, but I need to sort out some electrics for it.
    At the moment my only plans are to tow a car on a trailer so I don't need electrics for a caravan which makes 7 pin seem the easy choice.
    My concern is that I will be hiring trailers, I would expect most to be 7 pin as that is all I have ever seen, but should I expect them to change to 13 as that seems to be becoming far more common with caravans? Because the socket is hidden behind the rear bumper and faces the ground at 45 degrees there is really limited space for an adaptor.
    92 Audi 80 Quattro => RS2 Saloon!
    98 TVR Cerbera 4.5
    63 Austin Mini Super Deluxe (turbocharged)
    69 Austin Mini Cooper
    71 MGB GT
    75 Daimler Vanden Plas 4.2L
    04 Kawasaki GPX250
    96 Subaru Legacy GT-B
  • benntenn67
    • Jun 2009
    • 859
    Go for 7 pin as 13 pin is relatively new - if you hire a new 13 pin trailer you can use an adapter
    Everything you need for towing, this place will help
    Audi S2 Coupe 1995
    VW Passat GL5 (hatch) 1986
    VW Passat GL 1.8 (saloon) 1986
    Carrera Subway 8
    • benntenn67
      • Jun 2009
      • 859
      ..... Forgot to say use a short extension lead then an adapter as you only have limited space - when 13 pin becomes the norm - re-wire
      Audi S2 Coupe 1995
      Carrera Subway 8
      • Sleeper_Avant
        • 2372
        13 pin towbar electrics are now subject to mot tests i belive, all my centres have the new tesing equiptment
        this may just be for cars fitted from new though but worth checking just incase
        1993 URS4 Avant Emerald Green 350+bhp
        1991 Ford Sierra Sapphire 4x4 in Magenta
        BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
        • 80Quattro
          • Sep 2006
          • 420
          http://www.maypole.ltd.uk/index.php?webpage=store.php
          That was what I initially thought as the last trailer I hired was definitely 7 pin, but since then 13 has become the standard. 13 pin would be more future proof as long as I can fit an adaptor in the space ok.
          7 or 13 are tested, but I think they only test the brake lights, tail lights, fog light and indicators. I wouldn't be wiring up the things I don't need if I did use 13 pin as it is a lot of hassle for something I won't use.
          98 TVR Cerbera 4.5
          71 MGB GT
          04 Kawasaki GPX250
