fault Codes
  • Martin62
    • Jan 2011
    • 187
    fault Codes
    Have just pulled the fault codes off my ABY during service with the following result:
    Engine:
    1. 00561 013 Mixture Adaptation
    Static - Adaption Limit (MUL) Not Exceeded
    2. 00537 136 Lambda (Oxygen Sensor) Regulating
    Sporadic - Regulating Limit
    3. 00513 003 Engine Speed sensor (G28)
    Static - No Signal
    The car is starting and running exactly the same as it always has during my ownership.
    Can anyone suggest my next course of action ?
    I also have the following for the airbag system:
    1. 00532 135 Supply voltage B+
    Sporadic - Signal too Low
    2. 0588 160 Airbag Igniter Driver Side (N95)
    Sporadic - Value of resistance too great
    3. 01025 155 Trigger for Onboard Diagnostic Lamp Malfunction
    Sporadic
    As usual, any advice greatfully received !!
    Martin
    AFAIK you always get the G28 without the engine running.
    Sounds like MAF and lambda
    • Rusty
      • 18953
      Yeah, the lambda code is certainly pointing towards that or the associated wiring.
      As Error surmised above, the G28 code always pops up when you read the codes, as the engine isn't on, so there's no engine speed signal
      • dm80
        • Apr 2005
        • 812
