This is probably one for UrS4boy, ....cue link to explanation
As shown in the ETKA pic there is a "brake force regulator" attached to the passenger side suspension arm to reduce braking force as the rear of the car rises under heavy braking. This much makes sense as it can reduce braking pressure to the entire back axle. From there the line runs into a T-piece mounted above the subframe which splits the circuit to the left and right brake caliper.
Now for the unusual bit, we discovered a device on the rear subframe which ETKA calls a "brake pressure regulator" which is on the line going to the driver side rear caliper. What we don't understand is why does it regulate one side and not the other?
Anybody got any ideas?
