Large Service Questions
  • Kim1978
    • May 2007
    • 12
    Hello everyone,
    so I bought an RS2 this weekend. I will post pictures and info about it later but for now I would like to get your input on a large service. The car has been sitting for quite some time and has some typical problems as a result of that.
    Anyhow this is what I would like to do:
    Brake discs x 4 (leaning towards Zimmermann)
    Brake pads x 4 (leaning towards EBC red stuff)
    Oil filter
    Engine oil (Castrol 10W-60)
    Spark Plugs (which ones?)
    Tranny Oil Castrol Syntrax fully synthetic 75W90
    Rear Diff Oil
    Air Filter
    Coupé Filter
    Fuel Filter
    Thermostat
    Timing belt + water pump
    Brake fluid
    Radiator flush & engine coolant change
    Power steering fluid
    Wheel rotation, balancing & alignment
    Check ignition timing
    Check and adjust all belts. Replace if any are cracked / worn out.
    And of course
    Complete cleaning and waxing of that car
    If you have any special recommendations or products I should use (or not use) I would be grateful if you let me know.
    Thanks!
  • stocious
    • Jul 2012
    • 838
    i used castrol 10/60 in my s2 recently. bloody expensive stuff. glad i did tho sounds sooo much smoother and quite
    1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
