I use a 58/65 ar 58.
1 bar at 4700rpm 2bar at 5100rpm and 2.5 at 5300rpm. On the road it kicks in a little earlier
ported head, bigger exhaust valves, race cams +++ alltough I could get some more boost at lower rpms with different cams, but it looses power on the top end.
That sounds about right to what I would expect. That turbo is pretty close to a 3076 so it sounds good enough.
I get on the similar setup the same boost curves, maybe 200rpm later.
Are you sure you would loose power? With a "small" 58/65 I guess the turbo is maxed long before race type cams are needed. 99% sure your car would be faster with not more then 7A type cams.
