Okay. I can NOT find the thread with the spring loaded harmonic
    damper at the end of the crank. It was part of a recent thread. Not in the usual places. Tried searching on "harmonic", "balancer", "crankshaft", etc. Nada (well not what I was looking for anyway).
    Please point the way for the blind.
  • driftin jo
    • Sep 2007
    • 2222
      Thanks but nope. That is not it. It was recent. Early this past week. Not sure which thread it was in.
      • Christophski
        • 3632
        Was it one rusty started?
        • driftin jo
          • Sep 2007
          • 2222
            Very close (and thanks driftin' jo for the link to rusty's thread). It leads to the I5 crank with the spring damper which is what I wanted as a key. However, IIRC, the same thread also had photos of a normal 20VT I5 crank and that is what I was really after. It showed the front end of the crank and specifically the "+" washer that drives the oil pump. I should have nabbed the photo when I saw it. Bugga.
            Thanks gents.
            • driftin jo
              • Sep 2007
              • 2222
              Thanks gents.
              There is some pics of that oil pump drive
              in this thread.
                in this thread. http://www.s2forum.com/forum/showthread.php?t=63612
                Yes thank you. (But still not the one from a few days ago, showed a photo of the crank from Cyl 1 end to Cyl 5 end, showing the oil pump drive location).
                I might have to settle for the photo from the AAN build (in the link)
                Thanks.
                • driftin jo
                  • Sep 2007
                  • 2222
                  I can take some photos of a
                  crank later if you like.
                    I can take some photos of a crank later if you like.
                    Sure, please. I am going to have another go at finding the photos that I remember seeing. I think now they might have been in a thread that was linked out of an older thread that was linked out of a recent thread, i.e. two or three layers down the rabbit hole.
                    • driftin jo
                      • Sep 2007
                      • 2222
                        Wow. Thanks very much. The rabbit hole search has officially been called off. Photos are great.
