Can anyone help? (Sorry about Another thread about oil-burners!!)
My Mate has this 56 plate car which has a regular miss which has been getting progressively worse. It's only present on light loading (worse when cold) but when pressed, will pick up its shirt-tails and pull well. Last weekend, we were both away with our families in our caravans (Sorry Lads
), and with his twin-axle on the back of the X-Trail, it pulled perfectly well (On WOT).
With engine running, bonnet open- it's obviously down on one cyl, but as the revs slowly increase the miss slowly disappears.
My initial thoughts were a badly dribbling injector, as he tells me that recently whilst driving it has started to occasionally white-smoke for a short distance, then a few seconds of rattling (he described as sounding like pinking), then clears itself again.
I suggested Forte Diesel Injector cleaner, but he was told there is no such thing (Did I dream that it existed??) and was sold Forte Fuel System Cleaner, which had no obvious effect.
Yesterday he had an 'expert' look at it, who listened to the injectors with a stethyscope and said 'The injectors are fine, I can hear the fuel travelling thro them'!!
Is It Me???????
This chap then plugged his Code-reader in, and said 'It's an EGR fault- it needs replacing/by-passing'
The car has done 70k miles, and isn't using oil or water.
Any suggestions Lads??
), and with his twin-axle on the back of the X-Trail, it pulled perfectly well (On WOT).With engine running, bonnet open- it's obviously down on one cyl, but as the revs slowly increase the miss slowly disappears.
Is It Me???????
