3b or not 3b !?
  • Gazmitchell
    • Feb 2013
    • 640
    3b or not 3b !?
    Hi all
    I'm on the verge of getting my 3rd s2 and wondered as I've had both, - abeit years ago - which would you buy if you had ther chance again 3B or the ABY and why ?
    What are the pros and cons of both models and is there any real difference bar the obvious ?
    Thanks for you comments
    Gaz
  • GazzaG60
    • 4133
    Id go only aby.
    6 speed, coilpack as a stock car dual mass.
    its a later car in general so hopefully better bodywork and potentially spec.
    itll be so much easier to find a good aby also id expect.
    • Gazmitchell
      • Feb 2013
      • 640
      thanks for the reply, ive had both - although was 18 odd years ago so not since theyve become a classic almost..!!
      • sidrick
        • Jan 2011
        • 1342
        As a 3B owner I wish I'd have went ABY.
        Getting hold of the following has been a nightmare that wouldn't have been the case with a later car:
        Window regulator
        Rotor arm
        Central locking pump
        Alternator
        • Cottis
          • Feb 2011
          • 1448
          Doesn't matter, just make sure it is a good one with a fat accompanying wallet to put right anything that goes wrong.
          I have a 3B but it took ages to find a really good one and I was starting to consider an ABY. For me, it was the original S2, a SM Flywheel and would possibly hold better value long term due to their numbers. I will no doubt be proven wrong but if you get a decent one, you wont care as you will be too busy smiling
            ABY, no question.
            Joined in 2005.
            3,000 posts.
            Hundreds of hours "wasted" on here.
            No one who has an ABY wishes they'd bought a 3B.
            • mcandmar
              • Apr 2004
              • 5118
              Originally posted by macspring
              ABY, no question.
              Joined in 2005.
              3,000 posts.
              Says the ABY owner with a 3B flywheel
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • stocious
                • Jul 2012
                • 838
                one that been looked after by people that know how.. above all else in my opinion.
                1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
                • irishs2
                  • Apr 2009
                  • 2455
                  Exactly:
                  A £6000 well looked after car, is cheaper than a £3000 one.
                  Eric
                  95 S2 Avant under rebuild.
                  • Colesy
                    • Feb 2009
                    • 2981
                    The only time I ever wish I had a 3b is when it's MOT emissions test time!!
                    Otherwise it's ABY all the way.
                    • GazzaG60
                      • 4133
                      that's the one factor I suppose colesy. one of the reasons I got the h plate b3 saloon is no cat needed. I had issues on the aby with no cats from time to time.
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        Talk about trying to start the "my type of S2 is better than yours" debate. At least you've ruled out an Avant, probably on the basis that they're ****.
                        Just have a go in both. They are very different in standard form.
                        Personally when I had the choice I couldn't live with the 6 speed 'box, dual mass flywheel, and unreliable coil packs.
                        But they both have pros and cons. It depends what suits you.
                        It also depends on what you want to do with the car in the long term. Keep it standard-ish, or modify the **** out of it.
                        @ sidrick. Yeah. It's a PITA when you have to treck all the way to the nearest large town to get these parts.
                        SS
                        • stocious
                          • Jul 2012
                          • 838
                          im glad someone put coil packs and unreliable in the same breath.. i thought it was just me .
                          no argument intended
                          • GazzaG60
                            • 4133
                            what id do to get rid of the dizzy on the 16v.
                            I never had a coil fail or any other part of the system for that matter. cam sensor yes, coils no.
                            it is an each to their own but I feel the point made about no aby owners want a 3b is bang on.
                            • Rocco
                              • Aug 2007
                              • 6393
                              • Country: Spain
                              Same state,same price ,always an Aby
                              If you want modifying and the 3 B is like 3000 EUR cheaper,then choose a 3b, and use the money
                              Abys are heavier and only worth to pay for his ecu, and gearbox
                              Pin swap,and tfsi coils and that's all
                              Gearboxes are easily conversionable ,but don't do it in the beginning.... Do it once you destroy the first
                              And after all, both sucks in factory spec so.... There's only one way to follow
