Brake lamps fuse -where is it located?
  • piotr
    • Jul 2012
    • 1470
    hi all.both my stop lamps not working.i found that there is no power to brake lamp switch so i would like to check fuse and here is small problem.its described as fuse number 29 and there is no more then 22 fuses(i think)could anybody advise where is the fuse located for stop lamps???Many thanks
  • johne
    • Apr 2007
    • 1405
    S29 is in the main fuse box but it's position in there is different depending on a 3B or ABY.
    If you go onto S2central.net, under Electrical systems, wiring and schematics the layout of the fuses is explained.
    John
    • piotr
      • Jul 2012
      • 1470
      thank you very much John.i found it.it is the one next to the 2 fuses covered with red Motor cap.its all working o now
        Something like this?
        • johne
          • Apr 2007
          • 1405
          Yes, if you've got ABY or ADY, but not if you've got 3B.
          John
            John
            I think you meant ABY and ADU. Is there a photo of the 3B fuse box somewhere? I would like to compare the two.
            Dave F.
