G40 Impending failure?
  • mcandmar
    • Apr 2004
    • 5118
    00515 - Camshaft Position (Hall) Sensor (G40)
    01-10 - Signal Shorted to Plus - Intermittent
    30-10 - Open or Short to Plus - Intermittent
    Twice over the last few weeks i've had difficulty getting the car started, both times i cycled the immobilizer on/off and the car started up so i thought nothing of it.
    Over the last week i am getting the above error codes almost daily now. Same scenario in that each morning i start the car and drive off, then about 30secs later the ECU light starts to flash and the above code is stored.
    Question is, does this look like a failing sensor, or a dodgy bit of wiring somewhere. What have others experienced with failed G40's? I thought they just suddenly died, usually when trying to restart when warm. I'm seeing the opposite, only get this issue on cold starts first thing in the morning, but it does start.
    Any thoughts? Obviously replacing the sensor would tell me more but would rather avoid the expense/effort if at all possible.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
  • irishs2
    • Apr 2009
    • 2455
    I had something similar, my g40 was intermittent short to ground and car would cut out.
    Eric
    95 S2 Avant under rebuild.
      G40 Hall Sender Failure and Replacement Info
      .... Obviously replacing the sensor would tell me more but would rather avoid the expense/effort if at all possible.
      As I had said before IrishS2 (Eric) posted up his issue before, there are situations where a G40 will fail and stop the engine while it is running. Some people don't believe this. They are still at the side of the motorway awaiting rescue by the RAC.
      My consolidated post on the issue (includes IrishS2's info, thanks Eric):
      You have the opportunity to save yourself from the RAC rescue. You need to buy a $10 Hall sensor from EFI Express and install it ASAP:
      EFI Motorsport is a company dedicated to providing quality upgrade parts, hardware, software, tuning, and service for a range of European vehicles.
      Replacement DIY here (click on each photo for more info):
      If you don't take this advice, you are in denial. It is the cam sensor failing. Don't be a victim, be proactive and change it NOW.
      • mcandmar
        • Apr 2004
        • 5118
        Very interesting, so it looks like i am on borrowed time. Awesome
        Wish i had a scope to attempt a proper diagnosis out of curiosity and all that. I know i have a new sensor i bought years ago that just needs riveted on. Question is can i find the damn thing. Fingers crossed for a sunny weekend..
        Cheers,
        Mark
        • irishs2
          • Apr 2009
          • 2455
          If you are stuck I can post up a new sensor to you, like yours it will have to be attached to the bracket.
          Eric
            Very interesting, so it looks like i am on borrowed time. Awesome Mark
            No Mark, you are beyond "borrowed time". You are staring at impending (engine) death.
              Put the tow rope in your car, and my number in your phone. See you soon !
              • mcandmar
                • Apr 2004
                • 5118
                Shh, it will be fine
                • mcandmar
                  • Apr 2004
                  • 5118
                  Originally posted by macspring
                  Put the tow rope in your car, and my number in you phone. See you soon !
                  Will it make it to Friday, place your bets...
                    Good luck. Don't forget the cold water down the cam cover (open it a crack) if the car doesn't want to restart hot. It helps to cool the Hall sender and get you started one more last time.
                    • mcandmar
                      • Apr 2004
                      • 5118
                      Does anybody know where i can buy a new 3pin connector for the sensor?
                      I had planned to install a new sensor onto the bracket and solder the existing loom/plug onto it. Problem is the wiring was all corroded inside, and each wire had over 2.2k ohms resistance from end to end so it wasn't usable. The original plug is a sealed unit so i cant reuse that either.
                      I wouldn't be surprised if the old sensor was fine, it was probably just the corroded wiring that was causing my problems. As a temporary fix i fitted a second hand sensor which is working fine but i would like to sort out the new sensor and have it ready to go.
                      Cheers,
                      Mark
                        Does anybody know where i can buy a new 3pin connector for the sensor? Cheers, Mark
                        Dealer or junior timer plug supplier.
                        General G40 info that discusses the connector plugs:
                        • mcandmar
                          • Apr 2004
                          • 5118
                          Great stuff, tyvm
                          • AndyP
                            • 6049
                            Cheers,
                            Mark
                            Pretty certain this will do if Audi don't have them
                            http://www.ebay.co.uk/itm/Genuine-AM...item20d3f9166a
                            • irishs2
                              • Apr 2009
                              • 2455
                              I think it's male you need coming off the g40 though. Female is on the loom side
                              Eric
