AAN,S2,7a water pipes diagrams?
  • Sleeper_Avant
    • 2372
    has anyone got (Dave?)
    any diagrams for any of the 5 cyl engines for water pipe routing please
    need a few ideas on re-routing a few things
    thankyou muchly
    1993 URS4 Avant Emerald Green 350+bhp
    1991 Ford Sierra Sapphire 4x4 in Magenta
    BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
  • Sleeper_Avant
    • 2372
    anyone?
    • andy10v
      • 5996
      One of Dave's
      Sold ABY-stock
      • andy10v
        • 5996
        SJM
        Sold ABY-stock
        • Sleeper_Avant
          • 2372
          Cheers Andy, had a look at the SJM one, didnt really help too much earlier so i posted this up
          all my water pipes are now mocked up mostly and i think i will use the "turbo coolant return" for the small air bleed off pipe that goes to the headertank on my B5 chassis
          and blank off the Water feed core plug for now.......... dont need them right now
          if that makes sense
          Cheers Andy, made my mind up with that help
          Sean.
          • andy10v
            • 5996
            Vagcat
            Sold ABY-stock
            • Sleeper_Avant
              • 2372
              Both Radpipes are sorted
              Bottom rad hose to thermostat housing + headertank feed
              Top rad hose to AAN water rail
              Small thermostat/block outlet following block fed by rear water rail (no Aux pump) going to heater matrix
              Rear of block above bellhousing also goes to heater matrix
              Turbo water return will go to header tank air bleed fitting
              Job done
              Cheers Andy
