Starter motor removal
  • robhanick
    • Sep 2012
    • 12
    Guys,
    In the process of removing ABY starter motor. Have lower bolt removed but does anyone know exact size of allen key stud for top starter fixing?
    Thanks
    Rob
    Originally posted by robhanick
    Guys, In the process of removing ABY starter motor. Have lower bolt removed but does anyone know exact size of allen key stud for top starter fixing? Thanks Rob
    I thought it was all normal external hex bolts (one M12x67 and one M12x80). If there is an Allen head bolt, it is likely to be 8 mm.
    • andy10v
      • 5996
      It should be two bolts, through the bellhousing.
      Sold ABY-stock
      • robhanick
        • Sep 2012
        • 12
        Thanks all.
        After closer inspection found the two bolts and no allen ket type studs. All now done with recon GSF starter. All working good and back on the road.
