Easy question A6 C4 doors
  • Duffelcoat
    • Jun 2010
    • 446
    Hopefully this is an easy question!
    Are the doors front and rear the same on all C4 A6s saloon or avant and therefore interchangeable.
    I know that the body strips are different (thiner) on the older ones, but is everything else the same shape and can the strips be swapped?
    Cheers in advance as always
    Audi S6
  • saltinot
    • May 2004
    • 1946
    The door shells are the same. The window frame/inner door on the rear door assemblies are different. You can swap the window frame into the shell and you are good.
    This is true for both C4 and B4 cars.
    • Duffelcoat
      • Jun 2010
      • 446
      Cheers, do you know if the strips will swap?
      Audi S6
      • merlin's S4
        • Jan 2005
        • 1539
        There are extra holes in the S6 doors for the door trim clips.
