Aby servo and master cylinder question
  • ryster
    • Sep 2007
    • 224
    Hi , just wondering if anyone can help with this . is the ABY coupe Master Cylinder and brake servo the same as the A 80. 2.0l 16v. That has the hydrolic system ?
  • ryster
    • Sep 2007
    • 224
    Plz ??
      Originally posted by ryster
      Hi , just wondering if anyone can help with this . is the ABY coupe Master Cylinder and brake servo the same as the A 80. 2.0l 16v. That has the hydrolic system ? Cheers
      Hydraulic.
      The 6A A80 RHD 2L 16v with the hydraulic servo-assist has a 894611021 tandem master cylinder (23.81 mm x 17.5/18). This is the same as the ACOQ with the AAH or ABC V6 engine.
      The ABY coupe tandem master cylinder is 441611021B which is 25.40 mm.
      I have no idea whether you can swap an ABY one into an A80 but they are two different parts, not the same.
      • ryster
        • Sep 2007
        • 224
        Thanks for that info I think the servo is the same tho
          Looks like for the rhd cars it is. PN 894612099A
