ECU coding advice
  • kninio
    • Aug 2004
    • 641
    • Home: Lebanon Current: United States
    ECU coding advice
    Hello , i recently boughet ecu for the s3 with sportech upgrade, and i fit it to the car , now i compare the coding of the ecu and i see its coded for vehicle without traction control, shall i code it for traction control as mine have it? or they intend to do this for some reasons? my original Ecu code was 26710 , and the current one is 10710 , any advice would be appreciated.
  • Monkeymagic
    • Mar 2012
    • 3419
    Go into VCDS and change the code. very simple.
    • Monkeymagic
      • Mar 2012
      • 3419
      it depends on wether you want traction control. i would think you would be logging faults with the abs controller else.
      • kninio
        • Aug 2004
        • 641
        yes i want traction control , cos our roads is bad and the asphalt is not good, so more save , i think the traction control is disabled on the ecu do to track race reason with previous owner.
