rear demister switch help
  • Vinny
    • Apr 2013
    • 222
    Hi everyone and happy new year to you all.
    I am wondering if anyone can help I broke my rear demister switch
    on my 3b 1990 coupe and am trying to get a replacement hear is a pic .
    Not even sure if this is the correct part ![IMG][/IMG]
  • Vinny
    • Apr 2013
    • 222
    • Vinny
      • Apr 2013
      • 222
      Sorry guy really sh*t at the picture thing.
      • Bowie69
        • Nov 2013
        • 2675
        893941503 is the part number stamped on the side of it, searchign Ebay shows not many of them, but these are the ones listed in the parts catalog:
        With A/C: http://www.ebay.co.uk/itm/2000-AUDI-...item1e834248bf
        Without A/C: http://www.ebay.co.uk/itm/Audi-A6-10...item2c733ac787
        • Vinny
          • Apr 2013
          • 222
          Cheers bowie a forum member has some like these but for some reason are not the same as mine there are no letters in my code and only four pronhs on the back..
            Originally posted by Vinny
            I am wondering if anyone can help I broke my rear demister switchon my 3b 1990 coupe and am trying to get a replacement hear is a pic .
            The old PN 893941503 is gone, the replacement is 4A0941503 which was used in the C4s and B4s so it will be easy to find used.
            • Bowie69
              • Nov 2013
              • 2675
              As above, the parts catalog lists the 4A... numbers.
              • Vinny
                • Apr 2013
                • 222
                Cheers fellas parts ordered
                Whilst were on the electrical topic in my car the electric window switch lights are on constantly even when the car is locked is this correct seems like a constant battery drain to me..and does anyone nkow if there are any central locking divices avalible which use a key fob to open and lock the doors?
                • Bowie69
                  • Nov 2013
                  • 2675
                  I think this is the right one: http://www.rclick.co.uk/product_info...roducts_id=671
                  DO check, I've not ordered or even fitted one of these,, just recommended to me!
                  Not sure why your switches remain lit, they do for a while to allow you to close the window up, but should go off after about a minute or so.
                  • Vinny
                    • Apr 2013
                    • 222
                    Cheers bowie just ordered it now ...
                    Can't wait more toys!!!!
                      Those lights in the window switches should go out after engine off AND when drivers door is open… check that the door switch wiring is good… turn your interior/courtesy light to the 'door' position and see if it stays on all the time - that will confirm the door switch wiring is at fault.
                      Let me know what year the car is and I presume it has central locking that is activated by drivers door so I can look at the wiring.
                      • K Simmonds
                        • Dec 2007
                        • 7627
                        The illumination in the window switches stays on for a couple of minutes after turning off the ignition, caught me out years ago with my first Audi.
                        1990 B3 2.0 80 quattro.
                        1992 C4 2.8 Avant quattro
                        1994 MTM RS2.
                        1998 B5 TDI quattro Sport.
                        2000 B5 TQS.
                          Well maybe it has changed over the years, but my 94-ABY definitely turns those lights out when you open the drivers door… There is probably a timer as well that turns them out N minutes after shutdown if the door is still closed but I have not gone looking for that !
                          • K Simmonds
                            • Dec 2007
                            • 7627
                            Just checked the ones on my 1990 3B as I couldn't remember exactly what they did, after turning off the ignition they stay on when opening and whilst the door is open but go off upon closing it. As you say there is probably a variation between the early and late models and there must be some sort of timer somewhere.
                            1994 MTM RS2.
                            2000 B5 TQS.
                              Every day a school day :-)
