Is it possible to replace a 87C257 with 27SF256?
Eprom replacement
Of course it's needed, otherwise the chip won't latch the inputs, it uses same bus to access RAM and ROM.Comment
So you think that every chip with same pinout operates the same?
I don't think you have any clue what I said in my last message. Maybe it's time to go back to school.Comment
You have no clue what a latch is. Are you trolling? Or just ignorant and determined?The 27c512 has different pinout so obviosly needs a latch
27C512 with latch adapter will work exact the same as 27C256 with latch adapter, there's zero difference between the two besides an extra address pin.Comment
) If you don't remeber the word you need to explain in another way , right ?
