Starting an Engine thats been idle for two years.
  • dhali7376
    • Nov 2009
    • 301
    Would like some advice on the above.
    Saw somewhere they removed plugs and sprayed wd40 into the cylinders first ? Also have heard remove fuel pump relay to get oil lubrication up and around the engine. Cars been standing in a nice warm garage if it makes any difference ?
    TIA.
    Take the plugs out and disable the fuel pump or injectors. Spin the engine over on the starter until you see a couple bar of oil pressure, then you should be good to go
    • dhali7376
      • Nov 2009
      • 301
      A quick reply. Thank you.
      • montyrs2
        • May 2008
        • 522
        Worth fresh engine oil too. Run it for a few hundred miles then do another oil change to make sure it's all nice and clean in there. For a £3 oil filter and £40 worth of oil it's well worth it.
        • sam80quattro
          • Oct 2006
          • 1496
          Battery charger. Turn key. If oil light stays on switch it off :-D
          • varia
            • 821
            • Current: United States
            oil change
              Originally posted by dhali7376
              Also have heard remove fuel pump relay to get oil lubrication up and around the engine. Cars been standing in a nice warm garage if it makes any difference ? TIA.
              If you told us what the car was, e.g. S2 we could point you at the correct injector or fuel pump fuses to pull to prevent fuel spraying into the cylinders while you crank the engine to get some oil circulating.
              For example, the grey 208 relay beside the spare fuses:
              • dhali7376
                • Nov 2009
                • 301
                Thanks for all the replies. Its a Rs2 (mine ). Have finally finished renovating the house now its the cars turn . Have been slowly collecting bits for it and need to start it to reposition in the garage so I can put it on stands and work on it.
                • bluequattro
                  • 2960
                  Peel cam belt cover back and see if belt is cracked?
                  I'm buying a car soon that's not been run since 2008- checking and maybe replacing belt is in the list.
                  First taking plugs out and hand cranking to check if seized, if ok then oil change etc
                  Turn over with pump off n plugs out, maybe having capillary gauge for oil to check pressure properly.
                  • Fat Audi 80
                    • 10547
                    If it has been stored indoors, change oil and filter and fire it up. . Change oil again soon. That is all...
                    The Perfectionist
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Where do you get oil filters for £3
                      • bluequattro
                        • 2960
                        Mines been outside
