fuel pump question
  • fuel pump question
    hi all any of you put a 044 pump into a b4 80 saloon ? its a 2,3 ng and i'm fitting a aby into it.is the fuel pump in the tank ? what mods will i have to make .
    thanks in advance
    Be aware you might need to match the FPR return flow capability to match else run rich at idle
      You need the basket from an Audi 200 to fit it.
        do i need a cradle for the pump ? to put in the tank .is the saloon the same as a coupe
          dam got rid of my old tank
            ok got one of those any more things i might need ?
              Long time since I done mine, but there is a fair bit of information on hear about it.
              From memory you just need the 044 pump and the 200 basket.
                Are the standard fuel lines big enough to cope with 500 bhp
