Seems I have a leak around the dip stick pressing into the block, any one else had this and maybe it points to breather pipes that may need looking at ??
Oil leak
Yes there should be a seal at the bottom of the dipstick. You may find it is still in the little boss on the block and not seated correctly. Fit it to the dipstick tube then fit the dipstick tube to the block
ABY p/n N 90461401
HTH
Imola B6 S4 AvantComment
