I have a 92 8v it's been parked up for 6 months went to start it no luck !
So after a little investigation I found the the injectors are wide open and fill engine with fuel
Removed plug for injectors on the end of rail and connected my meter and as soon as the ignition is power they have power and fuel pump is running all the time
Any Ideas
Has the ecu failed
Thanks
Any Ideas
Has the ecu failed Thanks
