What I5 Block Do I Have?
  • SA BOY
    • Feb 2011
    • 310
    • Home: South Africa Current: United Kingdom
    A question for you in the know. I have a 5 cyl petrol block which looks identical to the 7a minus the sensor mounts. But it is roughly 2mm taller? Any info would be great. Thanks.
    Any 034 mmm xxx casting numbers on the block?
    • SA BOY
      • Feb 2011
      • 310
      Will have a look tomorrow.
      • SA BOY
        • Feb 2011
        • 310
        Only number is 225103021B?
        • caterpillar
          • 2480
          no more ID..?? se by the 3. syl. there are a flat spot, and som nr or figs stamped in...( may use some sandpaper or steel brush...) right under the gasged surface, but on the left side..
          • SA BOY
            • Feb 2011
            • 310
            Trying to add pics to show id of block. There is an engine number AAYR R for replacement but will mean nothing to you guys as its South African specific only.
            • caterpillar
              • 2480
              next; what deckheight in mm from the top to bottom end.... and what bore in sylinder ( dia)... the replacament engine i had, had no marks, or the marks are made with paint...
              • rxl
                • 1913
                Audi-engine AAY, 2480 ccm, 100 kw Petrol only made in SA. Rare **** as the crank is perfect for Strocker projects..
                • SA BOY
                  • Feb 2011
                  • 310
                  This block measures roughly 222mm from the top to the bottom where the main bearing cap fits, bore is 82.5mm.
                  • caterpillar
                    • 2480
                    I DONT have any info about AAY... not for wv or audi... ??? strange.. etka goes from 1947-2007.... but it may be the wv 2,3 or 2,6 liters verson... ( 92,8 cranck??) for the t3...or?? the deck height and bore will tell more... are the block with oilsquirters ??
                    • SA BOY
                      • Feb 2011
                      • 310
                      You are absolutely right as I have 3 of these engines from the South African made VW T25 Caravelle / Microbus. But this block is different, measures 222mm instead of 220mm and has the 95.5mm crank and not the rarer 92.8mm crank?
                      • caterpillar
                        • 2480
                        do you have the cranc too?? meshure the stroke.... the org are 86,4... but 92,8 are in some rare t3 wv and toy DO HAVE the 2,5l petrol in t4 eurovan ( 110hp) with 95,5 stroke, but they does have 81,00 bore, and are the tall deck engine ( 236mm)... ( may be rebored 2,4 diesel, 79,5)
                        • caterpillar
                          • 2480
                          may the piston are flat top or does have the deap disch in.....???
                          • caterpillar
                            • 2480
                            are the rod length 144 or 150mm?? and the x pin 20mm or 24??
                            • SA BOY
                              • Feb 2011
                              • 310
                              Another pic to show its a petrol block and not a diesel one although it has the 95.5mm crank making it a 2.6 but has the 2.5 engine code.
