This is a good one. So to start with I had a noise from the near side which sounded like the inner wishbone bushes. So when polybushing wishbones my mechanic found a leaking strut and rustyish top mounts (rosejointed ones). So with new Spax and new standard top mounts with new nuts we still have this groan. It is louder inside than outside. Disconnect steering rack still same, replace one nearly seized track rod end same noise. Remove anti roll bar and drop links still same. So bite the bullet and polybush subframe. Guess what still the same. The noise comes from the bulkhead area and is louder inside the car. You can get it to do it move car forward once but noy a second time. same happens in reverse, drive on a smooth road and it drives fine. But it is one of those disconcerting noises which you think 'This is Dangerous'. It is more of a crack sort of noise the ones where the chassis leg is cracked but it isn't that. So any suggestions would be appreciated other than sell the car. Thanks in advance.
