server images into VM -how?
  • s2driveruk
    • 12696
    Struggling to load up 3 server images into VMware workstation 10 (trial copy).
    Any tips? not sure if it is me being a dumbass or the supporting documentation
    1992 3b S2 Coupe
    Are the images ovfs? or a different format. Should be straight forward to import, i normally use VirtualBox most of the time
    • irishs2
      • Apr 2009
      • 2455
      are you converting real to vm, or just want to get existing vm images working in workstation?
      Eric
      95 S2 Avant under rebuild.
      • s2driveruk
        • 12696
        they dont appear to have an extension...just a group of files to denote build versions and the type is '001' through to the final one for each svr. Full filename is like this:
        VM_SERV1_x64-Build_11.0.0.0.001
        1992 3b S2 Coupe
          What size are the files? Most likely in 2 or 4GB chunks for the VMDK files and should be a smaller file with the config parameters
          • s2driveruk
            • 12696
            700MB a piece Greg
            1992 3b S2 Coupe
            • s2driveruk
              • 12696
              they are to run a demo image...
              1992 3b S2 Coupe
              • irishs2
                • Apr 2009
                • 2455
                My memory is a bit hazy on workstation, but on vmware server, I had to create an inventory location / path, then put the images in the inventory and import them from there.
                Eric
