Audi A4 Problem - Please help!!!
  • anthonys2
    • 3512
    Hi Guys
    I have a stupid question to ask but and will be a simple solution with someone that has more knowledge than me lol!! There reverse lights are staying on when am driving along can someone please tell what the problem is and solution its a 53 pate A4
    One quick solution I have thought of is to take the bulbs out but that doesn't fix it longterm lol!!!
  • piotr
    • Jul 2012
    • 1470
    • Home: Poland Current: England
    possible your reverse light switch stuck .you will have to find it (on the gearbox) and inspect it.
    • anthonys2
      • 3512
      ok sounds like a job for the garage! Am guessing if its just a switch it hopefully simple enough to change?
      • piotr
        • Jul 2012
        • 1470
        its very simple job chap,if you have got basic spanners you could do it yourself or just diagnose it.find out where exactly the switch is located on your box and disconnect connector going to it.if your lights will go out,it means fault is related to switch.(hope its only going to be the switch)
        • Monkeymagic
          • Mar 2012
          • 3419
          It is an easy job.
          • anthonys2
            • 3512
            Thanks fellas sounds not to bad a job
            • piotr
              • Jul 2012
              • 1470
