Audi b4 3 spoke wheel question please help
  • Bbmossma
    • Aug 2014
    • 120
    I have a usnspec 95' b4 dropping a 20vt in and want to switch the wheel to a non airbag 3 spoke. It currently has an airbag wheel, and I have been told for the wheel to look right, I need two plastic pieces to install with the three spoke wheel. I guess these are only necessary for the cars with airbag wheels. If anyone knows what the parts are or where to get them let me know.
  • MARKMIDGE
    • Nov 2014
    • 339
    You will need the original cowling for 3 spoke wheel, it has a circular contact for the horn to work and you may need to change stalks if yours do not fit in the older cowling.
    • ChrisAudi80
      • Oct 2011
      • 236
      • Home: Norway Current: Thailand
      Yep, I did that switch a while ago on my 95 B4. Finding the 2 piece housing can be tricky. From the S2 IIRC and it has to be trimmed. The old switches fit, but the column housing needs to be modded.
      '96 UrS6 auto PRJ chipped E85
      '95 80Q AEB VEMS E85
      • stingeris
        • Oct 2014
        • 373
        • Country: Lithuania
        Hi there. I think you are trying to buy that steering wheel through ebay from me. As i wrote you before, you need two plastics. I can get them too.
        Audi S2 Coupe 3B
        Can't find Audi part what you are looking for? PM!
        -> Stingeris SHOP <-
        • bluequattro
          • 2960
          It's called a clock spring
          Needs fitting with stalks too
