I know a few of you here have experience with the T4 Transporters. I'm viewing one at the weekend. It's a 2002 2.5 TDI so I wondered whether anyone could give me some quick buying tips and things to check/look out for? Many thanks!!
T4 transporter buying advice?
'93 S4 Avant now back on the road complete with new shiny go faster bits.Tags: None -
The usual really.
Timing belts are important.
Oil leaks around bottom pulley, usually oil pump to block gasket. Time consuming job to fix.
Oil leak from oil filter housing, quick easy fix.
Look for judder in the clutch pedal, dual mass fly wheel.
Try to peal the copex back on the engine bay wiring loom. It runs across the engine from left to right and the insulation gets rubbed of the cables.
Can cause all sorts of faults if water then gets in. Several hours and several rolls of heat shrink and loom tape sorted mine.
Rust in the bottom channel for the sliding door.
Central locking electrics on sliding door relies on a striker pin that can be temperamental. £50 part to fix it.
I make it sound bad but there pretty hardy really mines about to hit 250K runs great.
Hope it goes well
BUT I DON'T WANT A NEW CAR!
1995 S2 Avant, Volcano Black
2003 VW T4 long nose X pack, (has become project) -
Coolant temp sender, fuel temp sender, timing belts!!!! , injection timing, pedal box, coolant flange leaks. Take vcds with you if you can.Comment
injection timing indeed!
i've got setting it down to a fine art now
2003 VW T4 long nose X pack, (has become project)Comment
Thanks for the help! I don't have vagcom unfortunately. I have a cheap VAG code scanner but I don't suppose that'll show if the timing's out will it? Where is the OBD socket on these?'93 S4 Avant now back on the road complete with new shiny go faster bits.Comment
Pretty much as said above and check for rusty arches too but mainly it's the electrics above the engine in the bay. That's the main issue. Also if it's not pulling right don't buy it as they cost a fortune to trace the issue and can take months to do so. I sold mine after almost £2k and 18 months of trying to solve the limp mode issue and replaced it with a 1.9td. So much simpler however the 2.5 tdi's are so much better and I do want another!
Oh and glow plugs are a bug ger to replace too lol. Check it doesn't leek into the cab from the aerial bung is the scuttle and if it has ripped/ missing seals on the sliding and boot doors then these can be costly to replace.
Check for service history really too. A well looked after one will last. An old dog won't.Comment
Socket is under the steering column and you can tell if it's not running right and it won't pull and will feel flat as tooComment
That will do to pull codes. You will know if timing is off idle will fluctuate and cold start usually takes a while etc.Comment
If you find someome who knows what they are doing mechanically then they are straight forward.. The 1.9 td is awful to drive. The 2.5 May be more complex but it's all worth it.Comment
get Dmitri to remap then glow plugs are no longer required
Buy a 2.5 petrol and have few engine problems instead of the diesel!
Check sills arches all panels and underneath for rust.
Mine rusted like it had sat in the sea(that's why I've sold it!)
I had a 2 l petrol-slow to start but would do 80-90 mph all day up the motorway
Check whatever you buy will do hot starts-temp senders don't seem to last too well(GSF stuff anyway)
Check insurance will cover it if it's a converted van with seats-some companies are arsey over seat conversions without safety certificates-even my genuine caravelle had the insurance moaning and wanting photos to prove it was an 8 seater-they think 9 sweaters are under cover taxis!
Go for the best bodywork you can, once they've started to rot you ll be forever chasing it with a mig.
Prices high due to scene tax too.
Look for alternatives (not merc Vito tho-they re worse)Comment
They are a good van if maintained by someone who understands them. They kept me in business for 2 years.Comment
