Help etka needed please asap
  • kninio
    • Aug 2004
    • 641
    • Home: Lebanon Current: United States
    Hi all , any one has etka online , i want to decode this vin and know which engine computer belong to it WA1LYAFE1AD005730
    thanks in advance
    Originally posted by kninio
    Hi all , any one has etka online , i want to decode this vin and know which engine computer belong to it WA1LYAFE1AD005730 thanks in advance
    Either that VIN is wrong or it is not from and Audi.
    Decoded Audi VIN Results
    VIN: WA1LYAFE1AD005730
    Digit(s) Parameter Code(s) Meaning
    1-2 Country WA Germany
    3 Manufacturer 1 Unknown code (Not valid for Audi)
    4-6 Blanks LYA Only used on USA VINs.
    7-8 Vehicle Type FE Unknown
    9 Check/Blank 1 -
    10 Model Year A 1980
    11 Factory D Built in Unknown Factory Code for Audi.
    12-17 Chassis Number 005730 Serial Number 005730
    In any event ETKA wouldn't provide any info like what you want.
    • kninio
      • Aug 2004
      • 641
      thanks , its right but i need etka online to get me option details
        Tell us more why it is right. Right for what? A proper Audi VIN starts witn WAU, not WA1 (exceptions being for the S6plus and and the RS2).
        The two Audi Factory codes are "N" for Neckarsulm and "A" for Ingolstadt. "D" = bratislava which makes it sound like a Skoda.
        Give us a few hints, we're not mind readers.
        • kninio
          • Aug 2004
          • 641
          its US car and year 2010 , so
          • saltinot
            • May 2004
            • 1946
            Hey, I'm unable to use this VIN also. Give it another look to verify it's correct and repost.
              Might be a US spec car but it is a 2010 Q7 made in Bratislava (as I suggested). What the VIN gets you is shown below. If you want more info, you'd have to get it from an Audi dealer. ETKA won't get you want you want.
              • varia
                • 821
                • Current: United States
                thanks in advance
                2010 AUDI Q7, salvage?
                • kninio
                  • Aug 2004
                  • 641
                  yes its , cos i want to buy ecu from it
                  • kninio
                    • Aug 2004
                    • 641
                    want to know the emission option it had so i can figure if it has the same ecu i want
                    • kninio
                      • Aug 2004
                      • 641
                      ill try tomorow with audi dealer and confirm if the vin was right
                        What do you think the emission options were? If it is a Q7 gasoline V6 made for the US won't it be fully equipped with catalytic converters and exhaust gas recirculation, no options?
                        • saltinot
                          • May 2004
                          • 1946
                          Unlike Audis in other parts of the world which can be optioned in infinite combinations the US models are built with a "standard" configuration as far as emissions goes. Several years ago there were different (read stricter) emissions in California so vehicles that were sold there had different emissions systems. Nowadays all Audis are what we call "50-state" legal.
                          That being said, the Q7 you are thinking about buying the ECU from should be the same as all the other ones with a 3.6l engine. In the last 20 years or so Audi has gotten into the habit of changing ECUs to newer versions mid production. While some of these are still compatible and can still be used with your application even if the part number is not exactly the same. Been there, done that.
                          While starting off with the VIN is a good start, I would do the same thing first. I would take a harder look at the part number of the ECU as to determine the compatibility with your application.
