Audi Coupe quattro "dogleg" gearbox
  • quattrito
    • Aug 2009
    • 739
    • Country: Latvia
    Hello,
    I have bought donor car for breaking and it has "dogleg" gearbox. Wanted to know how worth it is? It shifts good, it is a bit noisy but that's normal for it.
    I found code underneath it - CBR.
    CBR is a 6 speed ABY gearbox
    • quattrito
      • Aug 2009
      • 739
      • Country: Latvia
      Interesting, where the gearbox code is written originally for S2? From upper part where it connecta with motor I can't. This code was from under.
        Sorry I just realised I made a mistake, CGR is S2, CRB is RS2
        HTH
        • Cottis
          • Feb 2011
          • 1448
          I thought a CBR was a Honda ha ha.
          • mdz
            • Jun 2012
            • 775
            • Country: Latvia
            CBR is a regular 5 speed box from Coupe/80/A4 quattro.
            • _ShurikeN
              • Mar 2010
              • 733
              • Country: Russian Federation
              Not that regular. AAH only at least on 80/coupe.
              • Audi_CQ
                • 940
                • Country: Norway
                Originally posted by quattrito
                Hello,
                Are you sure it's a dogleg pattern? 1. gear down? Must be a custom box or wrong shifter setup
                • quattrito
                  • Aug 2009
                  • 739
                  • Country: Latvia
                  Yes all gears are reversed from the way it should be. 1st is where the 2nd should be and so on. Any thoughts of the value maybe?
                  • Audi_CQ
                    • 940
                    • Country: Norway
                    Box is used with wrong type of shifter mechanisme/setup. 99% sure
                      /\ This
                      • quattrito
                        • Aug 2009
                        • 739
                        • Country: Latvia
                        I was a bit incorrect. I attached photo of the gear order.
                        • andy10v
                          • 5996
                          Looks like a flipped linkage/pivot.
                          Sold ABY-stock
